Motor self -diagnosis witness light
13 years 9 months before #29502 by manual-mecanica
motor self-diagnosis witness light published by Manual-Mecanica
Hello, sometimes the light of the motor self -diagnosis witness, located in the center of the board, does it since it placed CNG, and does not do so followed, it is a second and goes out, I do not know what it may be, thanks for your time.
13 years 9 months before #29507 by manual-mecanica
Manual-Mecanica response on the Re: Light of the motor self-diagnosis witness
When the ignition time is so short and no failure, it can be due to a poor contact of any of the sensors or a small cut on the same board,
13 years 9 months before #29539 by manual-mecanica
:) Thank you, ensure the injectors and add oil, so far it was not turned on, it must have been a contact, thanks for the support !!!!!!!!!
13 years 9 months before #29540 by manual-mecanica
The Yellow color check Engine in the case of the Peugeot indicates that there is or there was some malfunction of some system that composes the engine (injection, ignition, admission) but also turns on when the mechanical part of the engine has suffered some slight damage that can be beginning to be generated, therefore and knowing that its vehicle is adapted to function with gas of the normal (+90) and if so, this factor can alter the ignition for self -control or could be the refrigeration system is not working on the most correct maenra, and in what can help you with pleasure, I hope your response.
13 years 9 months before #29567 by manual-mecanica
Thanks for the data, it is working well now, and if it may have been the temperature, I had a loss of water in a heating hose, happy holidays for all !!!!!!!!
