Peugeot 205
13 years 10 months before #29498 by manual-mecanica
Peugeot 205 published by Manual-Mecanica
Peugeot 205 Naftero. Well, walking begins to pull, as if the gasoline is over or if it runs out of current. The air, oil and gasoline filters have already changed; They cleaned the carburetor, changed the carburetor diaphragm, reviewed the gasoline pump and works well. Can someone tell me what problem can you have?
13 years 10 months before #29509 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot 205
Have you noticed whether when the pulls made black smoke, or if the pull is just pull and nothing else? It could only be dirt in the pond if the carburetor is new, or that the pneumatic advance I have an empty leak
13 years 10 months before #29514 by manual-mecanica
It's just pull, nothing more
13 years 10 months before #29515 by manual-mecanica
What I have noticed that the fault does it after walking for a while. When the engine temperature begins to lift
13 years 10 months before #29520 by manual-mecanica
Hello friend, you have reviewed the electric part
