3.3 Voyager engine does not start
13 years 10 months before #29570 by manual-mecanica
Manual-Mecanica response on the Re: engine 3.3 voyager does not start
Thank you friend and check the crankshaft position sensors, camshaft position and the computer is no spark if you could help me with the electrical diagram I would appreciate it very much. Saul d. c.
13 years 10 months before #29571 by manual-mecanica
I appreciate it with you the failure in case there is no spark and the computer the two sensors the crankshaft of the camshaft if you could help me get the electrical diagram I would appreciate it. SAUL DC
13 years 10 months before #29572 by manual-mecanica
What model is it and if it is American or national
13 years 10 months before #29573 by manual-mecanica
You already checked the transmission zip sensor if it has no signal there is no spark or gasoline
13 years 10 months before #29578 by manual-mecanica
If you already checked that there is no spark, then you have to check what the coil or coils is There is the problem, you have to follow the line that is not damaged by the harnes, I hope it has served you greetings ..
