Chevrolet Aveo, accelerates alone
13 years 8 months before #29369 by manual-mecanica
Chevrolet Aveo, accelerates only published by Manual-Mecanica
Hello friends, my car is accelerated alone, I already changed the IAC valve and clean the acceleration unit and remain the same, I would like them will help me and if someone has the workshop manual and you can upload it I would appreciate it. In advance thank you very much
13 years 8 months before #29373 by manual-mecanica
Manual-Mecanica response on the Re: Chevrolet Aveo, accelerates alone
Hi Victor, Question: Is it accelerated too much? or is it as if the engine was cold?, if so, have you tried changing the temperature sensor? Check first if you have any resistance in OHM, I do not have the manual but there is a program that is the (autodata) I am getting it but I still do not have it ... if you get it, it can serve you since some relevant data comes out in it.
Greetings and luck.
13 years 8 months before #29378 by manual-mecanica
Look at the car, it accelerates at normal working temperature if I stop at any corner, when I start up, it does not indicate failure in the panel, when the drunk is noticeable more and also, now the acceleration body disassemble again and I found the hose that connects the air filter to the broken acceleration body, I do not know if this influences, where is the temperature sensor?
13 years 8 months before #29386 by manual-mecanica
It influences you if it has a flow before air entrance if not, it does not influence anything, it has an accelerator per piola or is electronic
13 years 7 months before #29413 by manual-mecanica
It has a piola, to accelerate, thanks
