Problem with Dodge Stratus
17 years 7 months before - 17 years 7 months before #2935 by manual-mecanica
Problem with Dodge Stratus published by Manual-Mecanica
I have a problem with a Stratus 97, the case is that it starts and goes out almost immediately brings agency alarm they have already bridged or eliminated it, but they removed the alarm module I do not know if that affects. Time is fine has a corner in the spark
plug
Last edition: 17 years 7 months before by .
17 years 7 months before #2943 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Dodge Stratus
You have controlled with a manometro what refers to the fuel pressure or sees if the pump works may have a pump relay and only activate when you start.
17 years 7 months before #2949 by manual-mecanica
If I already did and keep doing the same ...
17 years 7 months before #2965 by manual-mecanica
Ok you already did it and that pressure you, gives the engine of your car is a multipoint or a péint mono the gasoline filter how long it has, you have checked if the 12 volts tension is constant in the pump, you have checked if you have an inertial interruptor is an interruptor that must carry it I am not sure if in the vain motor or in the suitcase on the one hand if you have the owner manual. The fuel flow (the current) of the pump, for the alarm you have to see how it was connected because each installer has its way of working.- Do these tests and make me know, tell me that fuel pressure gives you because it can be the bonba that does not give enough pressure.- Greetings Alf.-
17 years 7 months before #2981 by manual-mecanica
Verify if it is not your MAP on many occasions that happens when you turn it on and in an instant it goes out
