Ford Mustang 2006 Problem
13 years 10 months before #29343 by manual-mecanica
Intermittent problem Ford Mustang 2006 published by Manual-Mecanica
Good I need help to solve a problem with my Mustang's flashing.
The problem itself that when they did the adaptation for Spain did not do it well and the flashing work faster than normal as if a bulb was missing.
I was looking and the truth is that I do not clarify with the vehicle wiring, I have tried to put a resistnice equivalent to a bulb and it does not improve if someone has made the modification well that explains how to correct it thanks.
13 years 10 months before #29397 by manual-mecanica
Manual-Mecanica Response on the Re: Intermittent problem Ford Mustang 2006
You could try by changing the ampoules to say if they are of large balloon put it small and if they are small, if they are mixed it usually happens.
