Concorde vibration 93
17 years 7 months before #2931 by manual-mecanica
Concorde vibration 93 posted by manual-mecanica
Hello friends:
I have a problem with my concord 93 when the car is cold I put it in Drive there is no problem but at the time it is hot in drive and the car stopped this vibrates and if I place it in neutral stop vibrating.
The transmission has just repaired
someone can help me:(
17 years 7 months before #2944 by manual-mecanica
Manual-Mecanica Response on the Re: Vibration Concorde 93
You have controlled motor or change supports, greetings Alfredo
17 years 7 months before #2958 by manual-mecanica
I have not reviewed them to review my trust mechanic to see what to see if that is.
I had told me the mechanic that I fix the transmission that were not the supports since they fail in Drive or Neutra.
But I will check them better.
Thanks for your comment and support.
Greetings: Woohoo:
17 years 7 months before #2980 by manual-mecanica
The truth is not the motor and transmission supports since it vibrates hot but in cold and the always vibrating supports
17 years 7 months before #3059 by manual-mecanica
You already tried to check your temperature sensor, perhaps your problem does not lie in the transmission but in your mixture of fuel at normal working temperature or is injecting more or you are missing fuel, but also Check
