My Ford Escort does not start me
13 years 10 months before #29273 by manual-mecanica
My Ford Escort is not published by Manual-Mecanica
My Ford Escort does not start when it is cold until 3, there are and hot if someone started me, someone could aydar
13 years 10 months before #29320 by manual-mecanica
Manual-Mecanica Answer on the Re: My Ford Escort does not start
It is a oil tanker or not?
Check the carbon of the starting engine,
it could be losing fuel pressure and it is returning to the pond either because the lid of the pond is bad or it is the fuel pump would be failing.
If you can say more data.
luck
13 years 10 months before #29326 by manual-mecanica
Diesel or gasoline is important to know that the solution is very different in one or the other
13 years 10 months before #29327 by manual-mecanica
If it is diesel they can be the heater and if it is a neighbor they can be the distributor rather the advance valve that goes to the distributor for example
13 years 10 months before #29441 by manual-mecanica
It is 90 carburetor gasoline
