PEUGEOT 405 FRANCES DEMACIED AVANSADO
14 years 2 weeks before #29168 by manual-mecanica
PEUGEOT 405 FRANCES DEMACIADO AVANSADO PUBLISHED BY MANUAL-MECANICA
I have a peugeot 405 1994 French motor, injection, with gas when I pass it to gasol
14 years 2 weeks before #29169 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 405 French Demacious Avans
Hello friend .... I see it that way ...... if the car is originally gasoline and the ignition is not regulated then what you need is an anti -domain and that is achieved with high octane gasoline or/and putting an octane elevator additive
14 years 2 weeks before #29171 by manual-mecanica
Thanks I will try, but for the model with the super of 85 octans I should walk well
14 years 2 weeks before #29181 by manual-mecanica
The problem can be solved with an update of the motor unit or telecarga, or the chopped sensor may have bad
