GVROLET OPTRA 1.6 idle failure 1.6
13 years 10 months before #29136 by manual-mecanica
Refrei Falla by Chevrolet Optra 1.6 Published by Manual-Mecanica
hello. I have a problem with a Chevrolet Optra 1.6 2011. The symptoms are the following when the car is cold, it turns on normal and after 1 to 3 seconds it begins to go down and rpm are climbed to 2000 to 2500 rpm, the fault codes P0122 and P0222 Erre was present and they did not be registered again but the car is still with the same evil. I turn it off and turn it on and come back with the same failure ... any help will be welcome
13 years 10 months before #29140 by manual-mecanica
Manual-Mecanica Response on the Re: Broolet Optra 1.6 Ralenti Failure
Carefully check the accelerator position sensor (TPS), wiring connector and wiring for pauses, etc. Repair or replacement as necessary
• Check the tension in the TPS (they refer to a vehicle service manual for specific information). If the voltage is too low, it is indicative of a problem. Replace if necessary.
• If you have recently replaced TPS, it may be necessary to adjust. In some vehicles, the installation instructions called for the TPS to be correctly aligned or adjust, consult a repair manual for more details.
• If there is no symptoms at all, the problem can be intermittent and the cleaning of the code can solve the problem temporarily. If this is the case, then you must definitely check the wiring to make sure that nothing, earth, etc. the code can return.
