Hyundai Accent 2006 Petrolero the main fuse
13 years 10 months before - 13 years 10 months before #29166 by manual-mecanica
Manual-Mecanica Response on the Re: Hyundai Accent 2006 Petroleum the main fuse
Hello, a minute, but now it does not burn but the engine is turned off. And I have to erase the code to start and last a few seconds and the engine is closed again.
THANK YOU.
Latest edition: 13 years 10 months before by .
13 years 10 months before #29190 by manual-mecanica
Hello, as I had told you before, it is due to a fault in the Cambus system, the reasons that damaged it is for an envelope, which although you already repaired the alternator because there was an envelope on charge, but the Cambus system, you did nothing to him,
you must reset and see if the same code persists, if so attack and repair the Cambus area,
this area of ​​Cambus is very important because the entire information is very important because THE COMPUTER
Greetings
Greetings
13 years 10 months before - 13 years 10 months before #29232 by manual-mecanica
Hello, apart from thanking your orientation, your story that is already repaired, everything was because it did not have coals the alternator burn the main fuse then they did not change the fuse but the cables gathered to him so the system was heated, a relay and a white square diode were very hot, then the engine was extinguished to give it a game again the code was erased and it was the same.
But when the coals were changed, the current was regulated and the fuse was changed no longer heated the system and arranged.
LUCK.
13 years 10 months before #29253 by manual-mecanica
Well. ,, First that nothing I am not electrmecanico ,,, but if I have to deal with circuits in the workshop ........ what I would do would be to disconnect all the possible attachments and leave only those necessary for the engine to work that would leave you would leave only the harness of the computer and the gasoline pump ... to see q passes
. Nothing that consumes is the amount in the injection ,,,,, I think that in that way the cable that is in short ... lucky .... ready to
13 years 10 months before #29256 by manual-mecanica
Carbon was missing in the alternator.
It is already repaired very grateful anyway.
