Hyundai Accent 2006 Petrolero the main fuse
13 years 10 months before #29096 by manual-mecanica
Hyundai Accent 2006 Petrolero The main fuse published by Manual-Mecanica
Hello, I am intrigued because the main fuse of a Hyundai Accentro Petrolero year is burned, it was a scanner and the U00008 code comes out if someone can help me in any idea already thanks
13 years 10 months before #29112 by manual-mecanica
Manual-Mecanica Response on the Re: Hyundai Accent 2006 Petroleum the main fuse
Hi Jrdiaz
the code to which you mean indicates the following ... Cotrolyl Network of the High Tension Bus.
The Canbus is the collection center of all information signals and distributes signals for each of the computer controlled system.
The fact is that several sections should be reviewed,
reviewing the voltages of your alternator could start with this, you should check the lands of all connectors and terminals, there could be cables and loose connectors,
so that a fuse flys it is because there must be an envelope, or because a line would be collided entering short circuit
I hope I have helped you help
you.
13 years 10 months before #29133 by manual-mecanica
Thank you, take out the alternator and it has very little coals such as those difficult to find but when I arm it I will know if it was that or not.
13 years 10 months before #29150 by manual-mecanica
Hello, it was not the alternator now lasts a few seconds and goes out and gives that code, tomorrow I will check it.
13 years 10 months before #29153 by manual-mecanica
Hi Diaz How long does it last for
the fuse?
