Luv Dmax Motor 3.5
13 years 10 months before #29811 by manual-mecanica
Manual-Mecanica Answer on the Re: Luv Dmax Motor 3.5
Good ... I have a Luv D Max that the engine turns on and then turned off, they lowered the fuel pump, they checked it and this good, but immediately turns off, someone could help me :(
13 years 10 months before #29814 by manual-mecanica
Check the switch in the suichera
13 years 6 months before #33822 by manual-mecanica
B) Hello, if the oil pump has the oil pump since the nozzle carries the oil pump or another cause could be covered, it may be that the state is very contaminated by sediments due to the lack of maintenance, I get one with the same problem but this is 2007 and the crankshaft broke ... If you want to know more about your dmax just ask in something I will help you ...
