Hiundai Accent 96 raised from the glass in vent
14 years 2 weeks before #28972 by manual-mecanica
Someone can give me an idea of ​​how I can do so that when the glass of the non -rise window goes up.
Half losses when losing the Levante level. You have to push and accommodate the glass to be able to completely close.
Greetings.
14 years 2 weeks before #28989 by manual-mecanica
Manual-Mecanica Response on the Re: Hiundai Accent 96
Friend it may be that the glass is somewhat detached from the base that is responsible for raising it or the guide detached or left, if it is the guide it is easy only you adjust or mount a new one, if it is the paste you must send to check.
14 years 2 weeks before #29040 by manual-mecanica
Ok thanks, I will review it, I write you anything.
14 years 2 weeks before #29043 by manual-mecanica
Change the plush, that is, where the glass runs and then checks the maker if there is wear or mismatch ..
