PEUGEOT 306D Motor Motor Problem
13 years 8 months before #28931 by manual-mecanica
Motoot 306d Motor Motor Motor Published by Manual-Mecanica
I present myself:
I am from Spain and I have a Peugeot 306 Break 1.9Diesel, it is neither turbo nor HDI, it is simply 1.9Diesel.
Well the problem I have, when I am going to start the vehicle in the morning to go to work, there are no ways to start it, the engine revolves because I am trying to start but nothing, I have to get diesel manually in the engine and it is when it starts.
In principle I thought it was a problem of heater, but my surprise was, that it took him to a mechanical workshop and they told me that the heater were perfect.
The same thing happened to the battery, it wasn't about the drums either.
The truth is that I am a little worried, because I am afraid that it is a serious problem, although what reassures me, is that the vehicle is perfect, but it seems that Gasoil does not reach the engine, because when it has been parked for a short time if I take it again it works perfectly.
What do you think?
13 years 8 months before #28949 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Motor Arraque Problem 306D
Hello, I don't know if I can help you, but let's try. You have not changed the diesel filter, and that of the air, when you start the smoke as it is, if it is black, it is a problem of filters, especially of the diesel. Try purging the filter, if you do not know how to do it, it is very simple, from the bottom of the filter there is a tube, which is connected to a plastic nut, loosen it a little for the dirt to come out, then the first one again. But put a boat under so that the diesel does not fall to the ground. ALL THE BEST. You will tell me.
13 years 8 months before #28952 by manual-mecanica
Hello, if after changing or checking the filters as Buskape tells you the problem persists, it is that the circuit runs out of pressure, either because there is a fissure in pipes or the pump retention valve leaves it, the pear or bleeding pump is a point to check, if we already pass all this, it would be workshop work, well the palette pump or the regulation valve of the interior of the interior Failure, a test to be done is to place a lady with diesel higher than the engine, aspire by means of a tube of the input corner measurement to the pump and introduce it to go to the start after heating it with the spark plugs, so from the entrance we are eliminating failures and leaks in the outer circuit of the pump.
If you don't start, think about the workshop, there is luck, greetings
13 years 8 months before #28953 by manual-mecanica
If you do not start and you have the heaters in good condition and the preheater also, the most caused thing is that you have air in the system, or that the precion is lost from the ramp, you have the next ones with the pear or the Bombin Precion Board in the system and once the spark plugs are heated.
12 years 3 months before #41721 by manual-mecanica
The same thing happens to me, I have to give the manual button to load the circuit and so start. It is always that I leave it uphill, downhill, it does not happen. Once I left it downhill and I lost diesel. I don't know what it can be.
