HDI fuel pressure regulator
13 years 8 months before #28928 by manual-mecanica
HDI fuel pressure regulator published by Manual-Mecanica
Hello friends, I have a Peugeot 306 HDI with the following problem. When accelerating the engine it reaches 2400 rpm and from there it seems to run out of gas oil. The engine stops by magic every so often, if I get the contact and start start immediately. When the engine is running, when the contact is closed, it continues to walk about 3 or 4 seconds. The SCANER throws a P1138 fault code regulatory fuel pressure regulator or stuck regulator, but they told me that I discard other possible causes of failure before changing the regulator, which by the way is quite boneroso. Please request that someone can guide me a bit about what I must do
13 years 8 months before #28930 by manual-mecanica
Manual-Mecanica Response on the Re: HDI fuel pressure regulator
Hey, something similar happened to me, to you the light of checking the engine on the board?
13 years 8 months before #28936 by manual-mecanica
Hello friend, that light does not turn on, only occasionally a yellow light that is located on the upper left side of the board, but I have no idea what it indicates, it has a graph with the shape of a filter or container with liquid content
13 years 6 months before #30803 by manual-mecanica
Hi, Tenfgo the same problem as you and I don't see anything. Have you found any solution?
13 years 1 month before #35994 by manual-mecanica
Hello: I have a Citroen Xsara Motor 2.0 HDI, I started with the same problems, when the car stops the car was still in progress for a few seconds and with the motor light on the board the car does not pass from 2400 rpm.
The bomb is Bosch and the scanner gave me the same error as Mauro 72. It is the fuel precion regulator of the pump, there is no other than changing and solving the problem
