PEUGEOT PATAGONIC TEMPERATURE PROBLEM
13 years 11 months before #28882 by manual-mecanica
PEUGEOT PARAGONIC PARTNER TEMPERATOR PROBLEM PUBLISHED BY MANUAL-MECHANICA
Hello, I have a Peugeot Partner 1.6 HDI Diesl, model 2011 with 2700 kms. The issue is that it lifts me a lot of temperature and the thermostat does not turn on. I would like to know what temperature does the thermostat turn on? If the temperature it generates is normal? Above 90 .... If someone can help me .... Thank you.
13 years 11 months before #28894 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature problem Peugeot Partner Patagonic
Hello, in the engines of the current temperatures above the 90ºC are possible thanks to the pressure of the approximate 1 bar circuit, since the liquid by increasing the pressure by means of the relief valve its boiling point far exceeds 100ºC. However, the engine was slowed down with the stopped vehicle must implement the electilers to the one in a few minutes, and observe that the manometer needle descends, if so, the thermostat works.
All the best.
13 years 11 months before #28946 by manual-mecanica
The temperature of that engine is 92 degrees when the temperature reaches 92 grade has to teach the electro fan and make it fall about 5 degrees
13 years 11 months before #28951 by manual-mecanica
Total according to Calderon, what I did not know was the opening point of the thermostat,
a greeting.
13 years 11 months before #28954 by manual-mecanica
In the French the opening temperature can reach up to 97 degrees.
