I have problems with the oil of a che
14 years 3 weeks before #28812 by manual-mecanica
The focus of the oil precion of a Chevy Monza 2009 is turned on, I already changed the pump and the bulb and still follow the problem I can do?
14 years 3 weeks before #28820 by manual-mecanica
Manual-mechanics' response on the topic Re: I have problems with the oil pressure of a car
As a tip, measure the oil pressure with a gauge to be sure it's working. If the pressure rises, the cable might be pinched and nothing more, but make sure of the pressure first.
14 years 2 weeks before #29085 by manual-mecanica
Check if the cable is shorting to ground with the vehicle. If you replace the pump and the pressure remains low, you may need to start disassembling due to a possible problem with the bearings or poor oil maintenance
14 years 2 weeks before #29086 by manual-mecanica
First, check if the lifters (tap valves) are making noise. If they aren't, it means your pump is working fine, and the problem could be the sensor wire. If the lifters are making noise, you'll need to check the fuel pressure with a gauge. If the pressure is low, then your pump is faulty. Cheers, I hope this helps ;)
14 years 2 weeks before #29088 by manual-mecanica
The first thing you should do is be sure of the pressure; measure it with a pressure gauge. You should do this with the engine at normal operating temperature so that it is a real and reliable reading. If that test shows a low pressure result, you should be concerned, because it could even be wear between the metals and the crankshaft.
