I don't know what happened they get wet from gasoline the spark plugs
17 years 7 months before #2962 by manual-mecanica
Do you have any alarm or corturient system because it can be that you are cutting the coil current that engine that has an independent coil or coils to each spark plug? Greetings Alf.-B)
17 years 7 months before #2982 by manual-mecanica
Thank you short circuit I really do not know if you had alarm or short circuit but I will check it out of that, I had not done because it shows that it does not bring, what if it brings is several bridged wires even in one where a rely is going is bridged if I take it off and I put the relev I do not go out good I will see that thanks for your time.
17 years 7 months before #3030 by manual-mecanica
Hey what happens so much silence, let you know that you are doing so we can continue to help you if you want but if you do not inform us we cannot do anything because the one you have the car is you.- Greetings Alf.-
17 years 7 months before #3033 by manual-mecanica
I hope that they apologize but apart from the cars that are wrong I have a problem in the house with one of my daughters and the truth takes away a lot of time and the one that I have left I am sorry for the jetta that as I comment is failing but turns and takes me and takes me and the pick-up does not turn on and by the way to the jetta I put hand of another suggestion that gave him another partner to fix his car and serve me and serve me to The Jetta is better because of that I had not put me on this page since I have very trimmed time with the problem of my daughter but in a thousand ways I apologize for having stopped communicating with you in advance I thank you for your understanding see you later and lucky lucky.
17 years 7 months before #3034 by manual-mecanica
I am at the order in which you can help you greetings and that you resume all your problems.-Alf
