I don't know what happened they get wet from gasoline the spark plugs
17 years 7 months before #3057 by manual-mecanica
The first thing I recommend is that you check your engine pressure, the pressure of your gasoline pump and at the same time check if your injectors are not being open, if so your problem is that the machine is drowning with gasoline, of being compression possibly a valve if it does not mark anything or very low rings, I recommend you to start somewhere ok?
17 years 7 months before #3074 by manual-mecanica
My good short circuit Thank you for your good wishes and I wish you the best forever see you soon and lucky.
17 years 7 months before #3075 by manual-mecanica
Tornillin thank you very much for the advice if I have thought about doing it but I have no compressro but I will get it and I do not know if someone knows how to test the injectors and if I could tell me how it is done in advance a thousand thanks well good luck good luck bye.
