I don't know what happened they get wet from gasoline the spark plugs
17 years 3 months before #2874 by manual-mecanica
I don't know what happened, the spark plugs published by Manual-Mecanica
Good to everyone I hope you can help me out of the problem I have a Ford Ranger 89 and rattle and there are times that it stopped and threw many explosions the tun-up and improved but I continued failing he got into the computer and that the bombs were bad Spark plugs and they were full of gasoline and so it is no longer turned on someone can help me, thank you in advance.
17 years 3 months before #2889 by manual-mecanica
The explosions on low and the petarders are due to ignition failures, the pick up, it had been warning of a ignition failure when doing this you comment.
When he didn't want to start and the spark plugs soaked in gasoline came out, it was because the ignition finished breaking and the spark plugs ran out of spark.
The first thing is to remove the spark plugs from the butt and with them outside, turn the engine with the start to see if there is high voltage current.
If there is no current and depending on how the ignition is (since I do not have the technical details of that engine) it will be time to look at coil or ignition coils, crankshaft position or camshaft sensors if it carries them, contact current in coil and in ignition module, distributor's draft ... etc.
All the best.
17 years 3 months before #2897 by manual-mecanica
Hello, I had inm with similar symptomomes and at the end of spending money on the DIFORD and other dealerships and tried a piston and tube to repair the cylinder head
17 years 3 months before #2899 by manual-mecanica
Thank you Megabeat_1 I will do what you recommend waiting for me to compose if you are not left without a car since I don't know what happens to you and also walks in the last lucky.
17 years 3 months before #2900 by manual-mecanica
Toletote thanks for the comment I hope I find the solution without having to disassemble the engine but if not even way I hope I do not run out of a Lucky Bye.
