Stratus 2.4 Transmitted Failure
13 years 11 months before #28725 by manual-mecanica
Stratus 2.4 Transmitted Failure Published by Manual-Mecanica
Hello my question, it is the following I have a automatic Stratus 1996 and the transmission is failing, it stays in second in "routine" mode the specialists in automatic transmissions told me that they are fine of the transmission and the electric transmission (soleniodes, sensors etc) tell me that the failure is of some engine sensor ... my specific question. of automatic transmission.
13 years 11 months before #29002 by manual-mecanica
Manual-Mecanica Response on the Re: Transmitted Stratus 2.4 Failure
There is no engine sensor that affects the transmission, and indeed if you have a trotansmiision failure either hydraulic or electronic
13 years 11 months before #29017 by manual-mecanica
Greetings were, in some automatic vehicles with electronic box if there are sensors that share with the motor ECU, as an example the Isuzu Trooper 94, shares the TPS, the engine temperature sensor and the RPM (Ignition module), including the TCM also manipulates the deactivation of the A/C compressor at times where they demand thrust force. The most suitable here is to scan both computers (ECU, TCM) to rule out electronic indole failures (sensors and actuators).
