Help with Pointer 2007
14 years 1 week before #28690 by manual-mecanica
Help with Pointer 2007 published by Manual-Mecanica
hello everyone.
I have a problem, adjust a 2007 Pointer engine and by mistake when removing the zipper or steering wheel remove a teeth that apparently takes the signal the crankshaft postison sensor or I believed that only the speed sensor but now I do not know what position it carries that teeth and does not start the car and the engine synconization is fine so I am sure that it is sure that it is sure that it is sure that it is sure that it is sure that it is for that
Will anyone have the diagram of how is that hoop going? Or can help me.
thanks to all
14 years 1 week before #28698 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with Pointer 2007
I do not have the diagram but the most logical thing would be that it would be marked or with a key for its installation, now if it does not bring anything at all and it is of efcto hall, then it tries to put the upper dead point for the upper dead point for the number 1 piston, in comprehensive obio and confronts this ring with the reader just where the taken or the part is not dental or the accountant say and try to see how it will see how it will see how it will
14 years 6 days before #28737 by manual-mecanica
Kikemec wrote: I do not have the diagram but the most logical thing would be that he was marked or with a key for his installation, now if he does not bring anything at all and it is of effcto hall, then he tries to put the engine in a superior dead point for the piston number 1, in compretion obio and confronts this ring with the reader just where the taken or the part is not dental or the accountant.
Thank you for answering, in fact it is what I try since it seemed logical, but it did not work.
By chance you will have the workshop manual of this car?
14 years 6 days before #28744 by manual-mecanica
No TRMGO RL Pointer manual but if you give me the data I see in the Autodta to see what we can do
14 years 4 days before #28806 by manual-mecanica
Take photos of the piece that you removed already the place where you are installed to help you, where are you from, Mexico ??? and post them !! So we surely help you easy.
