Peugeot 206 hdi does not start
13 years 11 months before #28621 by manual-mecanica
Peugeot 206 HDI does not start published by Manual-Mecanica
Hello, I have a Peugeot 206,1.4 HDI and its operation has been normal, yesterday I went to start it and the engine does not move, the witnesses are enclosed and goes out and does not move anything, we put the tweezers with another car and the same, we tried to give a push and nothing. They have some idea
thanks thanks
13 years 11 months before #28622 by manual-mecanica
Manual-Mecanica response on the Re: Peugeot 206 HDI does not start
Hello, you will check the impact sensor to have if a jumped is an interruptting one that ba was hosted winged at the shock absorber is red.
13 years 11 months before #28627 by manual-mecanica
The truth when you put the key, the witnesses are ecolated, you give to the contact Uy go out, there is a relay under the flying steering wheel, after suddenly it is removed and everything goes out, if you think it is the impact sensor, it is next to the battery in a box that is of relays and connections, or near the shock absorber, forgive for my inexperience.
Thank you
13 years 11 months before #28632 by manual-mecanica
If you have a tension drop it is not the sensor is the battery, if the tweezers are not good hello battery of the other car is lower of amps you can never start or have push because it needs tension to feed the injectors verifies well the battery I think you have evil there are, greetings.
13 years 11 months before #28704 by manual-mecanica
If you do not make noise you can have problems with the starter engine.
