Sprinter warming
13 years 11 months before #28685 by manual-mecanica
Manual-Mecanica Answer on the Re: Sprinter heating
Look as caused as you have the blown lid joint and pass you water for the water, other times when the joint is blowing the comprehension to the water and that is when the mangers are inchan.Prova remove the lid and control the joint
13 years 11 months before #28688 by manual-mecanica
Holas As the friend who wrote previously is the oil cooler is usually stooping with the oxide or drying the o'empesa o'empesa to pale the oil to the devoted water to which the oil has more pressure than the water the heating is by the elaceite that is covering the cells or gutters of the radiator I supply that you see the oil cooler. Some time and vote the water to remove the sist oil. of refrigeration. Oh, you look luck!
13 years 11 months before #28689 by manual-mecanica
Thanks for your help, the oil cooler is chopped
13 years 11 months before #28711 by manual-mecanica
Hello, could you solve the problem or not?
How many km does the engine have, if the cooler is eaten, I suggest you use an anticorrosive refrigerant Recognized brand anticorrosive refrigerant, which complies with the Mercedes Benz standard indicated, in the indicated proportion 55% product + 45% water.
Never use those preparations that have a very low product proportion and are unknown brand!
