DIRECTION PROBLEM
13 years 11 months before #28577 by manual-mecanica
DIRECTORS PROBLEM PUBLISHED BY MANUAL-MECANICA
Hi, I'm new here I have a problem, take out the direction pump to get a broken hose and now I could not fight it well the direction is some other methods to purge the circuit ...
13 years 11 months before #28586 by manual-mecanica
Manual-Mecanica Response on the Re: DIRECTORATE PROBLEM
You just have to turn the address on both sides completely slowly, several times while checking the oil level in the deposit and this already ;)
13 years 11 months before #28596 by manual-mecanica
Hi Roloxxxx, I agree with what the new partner in the comment comments, add to the comment that in the steering circuit there is a maximum of 1.5 liters of direction hydraulic oil, between 0.75 and 1.5
13 years 11 months before #28609 by manual-mecanica
Indeed, that is the most used method, so you have to repeat the process in when it does not give very good results, you can lift the car and do the process with the car without touching the ground, turn the steering wheel from one side to another loading a little in the stops, obio without the deed cover tanked and accounts us.
