MEGAN 2 CANBIO LEVER COLLURA PROBLEM
13 years 11 months before #28575 by manual-mecanica
MEGANE 2 CANBIO LEVER PUBLISHED BY MEGANICA-MECANICA
who could help me solve this slack problem on change lever.
In point, it moves from left to right also in the position of gears the marches enter well.
I leave you a video so you can see it better.
13 years 11 months before #28615 by manual-mecanica
Manual-Mecanica Answer on the Re: MEGANE 2 CANBIO LEVER SOLGURA
Disassemble the central panel, so that you have access to the base of the lever, and Czech if there is still the spring that focuses the lever, it is only Olgura de Palanna, nothing serious, disarms and see if there is a lot of wear, now if it is with Barillas below the car like Renault Clio, it could be the bushing that arrives and nothing else.
13 years 11 months before #28710 by manual-mecanica
Thank you, I'll tell you how it goes.
13 years 10 months before #29345 by manual-mecanica
It was the spring that focuses the lever was broken and problem solved and again a thousand thanks
13 years 10 months before #29392 by manual-mecanica
You're welcome for that we are.
