Water from the coolant is getting into the engine oil
14 years 1 month before #28540 by manual-mecanica
Coolant is getting into the engine oil. Posted by manual-mecanica
Hello everyone, I have a 2006 Opel Meriva 1.4 and water is getting into the oil pan. The car hasn't overheated and isn't overheating, and it doesn't have an oil cooler. My question is, what could I check before removing the cylinder head? Thank you all very much.
14 years 1 month before #28542 by manual-mecanica
Manual-mechanics' response on the topic Re: Coolant entering engine oil
Is water getting into the crankcase? If water is mixing with oil, it's the head gasket and nothing else if you don't have an oil cooler.
13 years 11 months before #30621 by manual-mecanica
Hello, good morning. I'm writing a little late, I apologize for not being able to do so sooner, but the problem with water getting into the oil is coming from the timing belt area. The inner cover, which has a gasket, had deteriorated. Thank you for your help and best regards.
