starting motor
13 years 11 months before #28459 by manual-mecanica
starter engine published by Manual-Mecanica
Good afternoon, someone can tell me how to disassemble the start -up of a CLIO 1900 D of 98. Thank you.
13 years 11 months before #28488 by manual-mecanica
Manual-Mecanica Response on the Re: Starter Motor
What is the implementation? distribution strap or starter?
13 years 11 months before #28492 by manual-mecanica
Hello, I mean the starter engine, I do not know how to remove it, since it has no access to remove it, it is behind the engine, but I do not see the fastening screws, I do not want to remove things that I do not need, if someone knows how to remove it, I ask you to please explain it to me.
13 years 11 months before #28541 by manual-mecanica
The starter engine must take it below the engine, you have to get under the car and disconnect the first cables, then you see if it brings nuts or screws, you have two opsions and you will see them below the vehicle, you are below or ahead but it seems to me that it brings them by back are two 0 three I do not remember well.
