Honda F18A3 engine (Rover 618i)
13 years 11 months before #28386 by manual-mecanica
Honda F18A3 engine (Rover 618i) published by Manual-Mecanica
Hello, I have lost almost all the oil because of this break that is next to the crankcase, as you can see in the following photos.
I don't know what is called what has been broken. This repair needs an expert mechanic or I can do it.
Thank you
13 years 11 months before - 13 years 11 months before #28442 by manual-mecanica
Manual-Mecanica Answer on the Re: Honda F18A3 (Rover 618i) engine
Aupa. I know what is broken is called a oil pump and everything because of the screw that holds the lower lid of distribution has loosen up and thus unscrewing to the pulley, where it received the coup of grace, total the joke in the official workshop € 800 (500pieces+300 mo).
From time to time to look, in case there is a loose screw _ your pocket will thank you.
Last edition: 13 years 11 months before by .
13 years 11 months before #28450 by manual-mecanica
When you break the oil pump, do not think about lighting the car will not lubricate and completely damage the Eye engine take it to a specialist
13 years 11 months before #28513 by manual-mecanica
This is very clear that this kind of intervention has to be done by a specialist mechanic and that the engine without oil is never started.
Thanks for the Council
a greeting from Santander
13 years 11 months before #28521 by manual-mecanica
Greetings There may be several things here can be the stretch or seal of the crankshaft that according to the type of engine is istalada in the oil pump or at the leash piñon of time now the way in which it loses the oil will tell you what it is if it is quickly and constantly are the stamps if it is slow ossea in days it can be the package of the carter is damaged and hot it boots the oil by this part
