- Thanks received: 2
Mechanics manuals
all about mechanics and technological news.
19-06-2025 Hits: 5143 Technology
Joni07 wrote: Uhm for the year should bring adjustable pills such as the Fiat or Renault but if it brings tachies or divers as you tell him you should try with taquies reactivator
Jesus_06 wrote: Friend, if you bring divers you must always download because if you do not make the noise you describe as a diesel engine. The way of downloading is with a bank press, they must be horizontal and oppress it, release it and check if it is already easily oppressed, if not it repeats the same procedure until it is easily when you oppress them friend, you will take a while because you must repeat it several times. One question, the order in which you placed them again was in the order in which they were mounted? Or did you not take that into account?
