starting problems in a Chevrolet Apache
13 years 11 months before #28257 by manual-mecanica
starting problems in a Apache Chevrolet published by Manual-Mecanica
Hi, I wanted to know if someone helps me.
I have a problem with a 2006 Chevrolet Apache.
What happens is that oil does not reach the injectors.
Greetings and thanks.
13 years 11 months before #28261 by manual-mecanica
Manual-Mecanica Answer on the Re: Starting Problems in a Chevrolet Apache
You have to say what tests you have done, what fault codes gives you to help you. You have to see if the fuel pump works and if you have the necessary voltages: in injectors, sensors, coils
13 years 11 months before #28278 by manual-mecanica
You have a raill or mechanical injection injection, depending on that the failure can be many things
13 years 11 months before #28301 by manual-mecanica
Has been reviewed with Scanner?
If it is Common Rail pressure problem
if it is a bomb with mechanical injectors check if it turns on the key damage witness that is blocking,
more test information is needed
