Ford F-Super Duty Mod. 95
13 years 11 months before #28222 by manual-mecanica
Ford F-Super Duty Mod. 95 Published by Manual-Mecanica
Hello, I would like to know if someone can send me the diagram of the Camper Ford Super Duty Mod 95 Automatic What happens is that the insurance of the flying column does not unlock when stepping on the brake, thank you
13 years 11 months before #28227 by manual-mecanica
Manual-Mecanica Response on the Re: Ford F-Super Duty Mod. 95
Friend I don't have the diagram, but I know the lever has a solenoid that the work after placing the lever in Park. By stepping on the brake brake swich, the solenoid activates to unlock it. If the Swich and solenoid work properly and does not uncover, it can be due to wear in the mechanism of axes and bushings or loose bolts as in a case I had.
