Voyager 89 cuts the gas after a while
17 years 6 months before #2855 by manual-mecanica
Manual-Mecanica Answer on the Re: Voyager 89
PS that happens do not say if you checked the relay and because of the valve that has broken the hose put a plug while and if it continues to check the lines of the gasoline that go to the monopunto injector it is easy I think that a 5/8 and 3/4 is deals with and open the switch if gasoline comes out ps is a relan
17 years 6 months before #2872 by manual-mecanica
Hello again, according to the mechanic and the fault code that came out 12, 42, 11, 55; He told me that it was the relay of the gasoline pump, because the wiring was changed and checked and still the same fault continues, now it does it more often and almost or ignites the engine, so now the fault is worse, after changing the relay, the code 12, 42, 55; Code 11 is already deleted but the other codes continue and I finish the battery charge and sometimes it does not even start and when it starts it only takes one or two minutes and as if it accelerates and ends up going out. Can anyone support me?
17 years 6 months before #2902 by manual-mecanica
Now I remember in an ocation a problem similar to a voyager only that I do not remember what model it was, and the symptom was that suddenly it did not turn on and the voltage the relia was lost I am talking about the shut Down rerey is the one that goes next to the battery, and the problem was that the voltage that the reluct was lost was lost to the cables that connect to the Sensor Sensor. The one that orders PCM (computer) to act to the Shut Down Relay, check it and luck.
Mexico
17 years 5 months before #3032 by manual-mecanica
Hello, please tell me the 12,42 and 55 code that they mean because I do not have it now, I would like to know if you have not hit the car in those days, or if you have walked by Caller with many holes or very deteriorated because if so it controls the inertial switch it can be that it has jumped you must be in the engine or the rear of the car to the sides to the sides
16 years 2 months before #9283 by manual-mecanica
Manual-Mecanica response on the Re: Voyager 89 the gasoline after a
More or less the same thing happened with my voyager only that I changed the hoses that come from the gas tank when changing them did not fix my The measures but it seems to me that they are two of a room and a smaller one that little one was the one that stayed crushed, you already changed the gas filter but try to use the original, I hope my answer helps you anything we made our hand
