Voyager 89 cuts the gas after a while
17 years 6 months before #2821 by manual-mecanica
Voyager 89 The gasoline is cut after a time published by Manual-Mecanica
Can anyone help me with my 1989 voyager? After a time of walking, the gasoline is cut and wanting to start again it takes a long time, it has even taken 2 days to start. I already changed the ignition coil and the spark plug wires, also a couple of years ago I changed the gasoline pump, which can I do the most to work for perfection? Thank you.
17 years 6 months before #2822 by manual-mecanica
Manual-Mecanica Answer on the Re: Voyager 89
Look at my good JFPS that to spend by spending this half -head Put it direct if you do not work ps that happened to me and it is the same and it was the pure relay I hope to be able to help in something luck writes to know what I had Sale bye.
17 years 6 months before #2823 by manual-mecanica
I appreciate your opinion, as you said it I already did the fiber of gasoline and in Efcto, gasoline passes, but the pressure is not how much it should be, now, I would be missing to check the relay and check if it overheats or that happens. Now, if you can continue to give me more instructions, they will gladly be welcome to solve my problem.
17 years 6 months before #2832 by manual-mecanica
hello. I read that you have already changed the gasoline pump, first of all the internet locates the electrical diagram of the gasoline pump and identifies the voltage and ground feed of the pump and verifies either with a voltimeter or test light that there is a voltage available at the time of giving the engine, I have to try to turn on the engine, if the voltage is not available to check a series of fuses and reliefs that appear described in the electrical diagram. Voltage If available to use a gasoline gangster that connects in the injector rail and verify that you have a precion more than 30 psi, this to verify that the pump is working and also has the ability to generate suffering precion so that injector can spray the fuel.
I hope it will use you.
Mexico, April 18. 08
17 years 6 months before #2838 by manual-mecanica
Hello again, as they already told me, the gasoline pump, pressure and voltage was checked and everything is fine, check the PCV valve and find a broken hose and change it, but the problem follows, and I do not know if there is a way to verify if the PCV valve serves since I cannot turn on the truck. Now, could this be the cause of the fault? since it could be that suddenly the valve stopped working and causes the engine to drown. I await your comments, thank you.
