Ford Escort 1.8 TD Cold Start
12 years 11 months before #38703 by manual-mecanica
Manual-Mecanica response on the topic starting ford escort 1.8 Td
Another common and quite simple faults in these cars is the dirt and calcification of the terminals and the connection of the cables to the connection of the terminals that then connect to the battery. They are dirty, the current does not circulate well and as a consequence the resistance is created in the correction of the starter engine and this is not entirely satisfactory, apart from the state in which the heating can be found and the engine The compression is low royo : S )
