PEUGEOT 306 XR TIME BELT
17 years 7 months before #2802 by manual-mecanica
PEUGEOT 306 XR TIME BELT PUBLISHED BY MANUAL-MECANICA
Hello ... well, first to greet them all, I am new here, and I had problems with the belt of my Peugeot 306 xr. 1800cc and 8 warehouses, well, the belt was burst with its consequences, I did not think the previous owner when he said he was just changed, but hey. I already fixed everything but I can not find the marks to put the belt in its position, the mark of the crankshaft pulley is clear and I have no problems with this but for the pulley pulley of the camshaft I do not know what its piosión is ??? It carries a point and the external one by the face? Well, do anyone know where these points are going? Thanks for the help but I have not been able to finish this and I do not want to rehearse to avoid damage again ....
Thank you!
17 years 7 months before #2813 by manual-mecanica
Manual-Mecanica Answer on the Re: Time Strap Peugeot 306 XR
Hello, I hope you clarify with the image.
In addition to the draft pins, you must look at the belt brands.
In the crankshaft the good hole is the 8 mm.
All the best
17 years 7 months before #2814 by manual-mecanica
Hello, good night, it is easy and it is not, who has a prathian is easy who does not have it layers you make you difficult, well, they go my comments, the pulley marks the point of the crankshaft.I You see that the two are balanced, that is the point of Arvol de Crís Cores again the crankshaft for the pulley brand you put the belt the eStics giving it a siege ease so that if you press it, you will have to have plovlemas other things, well I hope to fid
17 years 7 months before #2816 by manual-mecanica
Hello ...
thanks to both, well I have searched here and lower the manual stop the car and there was everything ... I mean it already turned on !!!! And furate perfect, thank you again !!!
17 years 7 months before #2824 by manual-mecanica
Always remember the basic principles of a tuning of an internal combustion engine ...
