Windstar 2001 kicks when putting in drive
14 years 1 month before #28018 by manual-mecanica
Windstar 2001 kicks by drive published by Manual-Mecanica
Winstar 2001 kicks when putting in drive 2 or 1st the reverse enters soft has codes related to oxygen sensor and one that is p1401 that I am checking if you can help me very much
14 years 1 month before #28022 by manual-mecanica
Manual-Mecanica Answer on the Re: Windstar 2001 Patea when putting in Drive
Brother If you kick when putting those speeds, it is because the engine is a bit accelerated, the engine must be in at least 800 cells when we apply a speed now if it is above 1000 tends to paw since it enters with torque to the mow of mowing .. Check what the other code is the sensor of oxygen can influence the acceleration since the ECU of the car detects failure in combustion and they have to inject more fuel normal.
14 years 1 month before #28046 by manual-mecanica
The rpm are normal are in 800 and yet kicks and the reverse enters all the changes they put very well
