A lot of smoke by diesel car, help !!!
13 years 11 months before #27959 by manual-mecanica
Manual-Mecanica response on the Re: a lot of smoke by diesel car, help !!!
Cordial greeting, as first you have to see what type of motor it is and if you have electronics or common rail or mechanics like this you can start diagnosing your car, if it is electronic you have to do it to see what the system has, thanks Jaimeji
13 years 11 months before #27963 by manual-mecanica
I hope not to be very repetitive, but thank you all for answering, well the injection is produced by pump injector, then to step on all the marches and upload it around, it is a little scared, because I am afraid to break it since it is a diesel car, and then the erg is new that changes it very little, greetings !!
13 years 11 months before #27982 by manual-mecanica
If the car is delayed on, it is very possible to be the injectors, if this bn, there is ke thoroughly squeeze it in all the marches per ke it is very possible that it is only carbon in the escape. Nor can the turbo discard, that is to say, it is loading bn. Good luck ....... anything is ........
13 years 11 months before #28000 by manual-mecanica
hello!! It is true that the car only releases me smoke in casualties, and when stepping on, the problem is that I am afraid to hurry the marches, for fear of spoiling the engine, is the engine risk when squeezing it like this?
