Citroen Xara Picaso 1.8 16 V Gasolina Corp Distrib
13 years 11 months before #27900 by manual-mecanica
Hello someone can help me. I have broken the alternator's strap and in the workshop they have told me that it has been tangled with the distribution pulley and I have broken the engine that must be opened and repair butt valves etc. I am out of work and without money as I can solve it I have notions of mechanics and I would like to know if I can do it, or where I can get information on how to solve it, someone can help me please I would appreciate it very much, thanks in advance in advance
13 years 11 months before #27901 by manual-mecanica
What necists disassemble?
Only cylinder head or whole engine?
Can you send me a engine photo to see how it is already disassembling cylinder head is not very difficult I expect your answer-
something else are you from Chile?
13 years 11 months before #27904 by manual-mecanica
Thank you for your interest, the truth is that I don't know much, those of the workshop have not opened the engine to know it, but it says that when the distribution strap is broken and left, the valves have been nailed and what opens, I suppose that it is normal when breaking the belt or can it be that changing the belt and putting it at its point start the engine? I await your answer and thanks
13 years 11 months before #27907 by manual-mecanica
Hello, well what the mechanic has told you is true, modern cars are very delicate therefore if you break the distribution strap, because what happened to you happens, if the pulleys have bother you you will have to take them out and put them new. Do not think that putting the new strap will start your cohe, it is more I would recommend that you do not try, you could annoy much more the annoyed. As for the repair, because it is expensive, but if you have a mechanical friend, to take a look at the car, while you disassemble it to fix it then better, but surely you can yourself, with passance and with time, good luck !!
13 years 11 months before #27923 by manual-mecanica
Don't you live in Chile?
Tomorrow I send you 2 photos of exara distribution belt that year you did not mention me
