Nissan armed se 5.6l 2006 went out running
13 years 11 months before #27881 by manual-mecanica
Nissan Armada Se 5.6l 2006 went out running published by Manual-Mecanica
Hello friends, greetings to all good I have problems with the Nissan Armada 2006 Motor 5.6l The problem is that I go out running and I no longer wanted to turn on it and it has gas has the injector what it does not have is spark
13 years 11 months before #27893 by manual-mecanica
Manual-Mecanica Response on the Re: Nissan Armed
Czech the state of the coil if you have a spark sign from the crankshaft sensor may not be amplifying it, you take advantage of checking cables and spark plugs, if it brings cables
