Water pump
17 years 7 months before #2783 by manual-mecanica
Water pump posted by manual-mecanica
How can I change the water pump of a 2000 2.0L engine, there is very little space to work
17 years 7 months before #2812 by manual-mecanica
Manual-Mecanica response on the Re: Water pump
HELLO. You have to disarm almost all that side, remove hydraulic pump support, Sigual pulley to be able to access the weather strap, \ "you have to remove it as well as the tensioner along with the base, the camshaft pulley immediately removes another back cover and you can unravel the pump \. This is because of the time band that is to know how to put on time otherwise valves can be counted and the soup would be more expensive than the albondigas. I hope to open you.
17 years 7 months before #2870 by manual-mecanica
Thanks for your answer, since I am fixed what I did was lower the car manual and study it very carefully so disarming it and installing the new pump and takes the opportunity to change the time band (it changes to the 168,000 kms. According to the manual) and this car brought 160,850 km Kms. Or more. Thank you again and we will continue to find ourselves for this route.
