Detroit motor failure
14 years 2 days before #27725 by manual-mecanica
Detroit Motor Failure Published by Manual-Mecanica
Hello everyone can help me with a cold motor failure, it turns it with ether when it starts to heat it goes out and no longer turns on it with ether and it is no longer kept on unless you have it accelerated it, you take your foot from the accelerator and turn off the truck is a 2008 columbia thanks ...
13 years 11 months before #28181 by manual-mecanica
Manual-Mecanica Response on the Re: Detroit Motor Failure
Apparently you have a problem with fuel precion with fuel returns, look for a possible flow restriction. And then you comment OK.
13 years 11 months before #28295 by manual-mecanica
What Karlof tells you add him that you could also have compression problems, check the rings through the inspection covers that you have in the block to see if there are no glued or broken (if I do not sink when pressing it is bad), if you have the tool measure compression, if you do not add some oil in each cylinder to try start. Luck.
Miguel
13 years 11 months before #28310 by manual-mecanica
Thank you very much for the information and locate the fault reveals the return is fine. The injectors were not dosing well since I work well thanks for your comments
greetings ....
