Titilea oil light
14 years 3 days before #27648 by manual-mecanica
Oil Light published by Manual-Mecanica
Hello, I have a Wolkswagen Polo. And I am bewildered several months ago I brought me in the form of pulses the light of the oil vigia. The pressure in the engine is excellent, and we already stirred everywhere and everywhere and we did not find the failure that the sensor accuses. If you could help me, thank you very much.
14 years 2 days before #27676 by manual-mecanica
Manual-Mecanica Response on the Re: Oil Light that Titilea
The first thing is to check the level, if you already measure the precion and it is right then the bulb can be bad, it is the first to do
14 years 2 days before #27719 by manual-mecanica
I would put a direct series lus to the battery and thus ensure not to have a problem in the installation
14 years 1 day before #27736 by manual-mecanica
It can be em Manocontact that indicates that the oil has pressure. It will be the subject of changing it
14 years 1 day before #27765 by manual-mecanica
Hello, look at the cables that reach them to the alternator in case they are cut or peeled ... greetings
