GOST BUE BOOD AB9 96
14 years 3 days before #27632 by manual-mecanica
Starting Burro Gol Ab9 Model 96 Published by Manual-Mecanica
Hello people I am new in this place, and I have a problem with the donkey of my goal an ab9 model 96. And I already entered the electrician 4 times and something always changes me, I change the coil, the fields, the brush, and I passed the same thing hot does not start. I have the goal workshop manual and I do not tell me anything I will tell me that in the circuit there is an intermediate auxiliary relia between the contact key and the donkey, and that this sometimes will be for the heat, if anyone knows where that relay is located in the rifle, please send me a plane or tell me. Thank you very much. I'm already tired of paying electrician
14 years 3 days before #27634 by manual-mecanica
Manual-Mecanica Response on the Re: Starting Goal Gol AB9 Model 96
Companion, look in the motor manual if there is said start of start. In the case that does not exist. At the moments that do not "start." You have to differentiate whether the starter engine turns, and the piñon gears in the crown. If this happens your problem can be on. or in the overheating of a file that possesses contacts. I hope it serves you.
14 years 3 days before #27644 by manual-mecanica
Thank you very much and I will control what you tell me and tell you.
14 years 3 days before #27647 by manual-mecanica
Tell me what happened to the end. : Laugh:
14 years 3 days before #27677 by manual-mecanica
If with the hot engine the start does not enter can be detached or damaged the Enbobinado that is communicated that it passes, if the start enters but does not turn on the vehicle tries to feed it with a battery land, but the best thing is when it does not start seeing what is needed. Chapa current, or land or if it is not the start can be in the distributor and its accountant the problem.
