Double Electrovantilador Saxo Vts
14 years 4 days before #27555 by manual-mecanica
Double Electrovantilador Saxo VTS published by Manual-Mecanica
I have an VTS 16V saxon from the year 2000, and I need to know where each double electro -ventilator connector are connected, I think 2 masses come out, and two connectors, well I have a connector that I have no idea where it goes, there are no loose connectors, and the fans do not jump, I hope to answer! ah! And I bridged the loose connector and did not jump
14 years 4 days before #27578 by manual-mecanica
Manual-Mecanica Answer on the Re: Double Electro-Vet Electrovillator
If it is a fan connector, they do not jump, you have to feed it with positive and negative current, the bulb is bridged that it is a negative and nothing else, Czech where the bulb is and bridge it to see if they leave but I think that does not bring,
