Scenic II 1.9 120 hp year 2004
14 years 6 days before #27500 by manual-mecanica
Scenic II 1.9 120 hp year 2004 published by Manual-Mecanica
Good I find myself in the situation that my Scenic's last card was stolen, and due to economic problems I do not currently have resources to buy another the car is parked a few 50 meters from my garage and I have already been notified of removing it from the street, or they take it out of abandonment. There some way to start it without tarjta since the car asks for the card for the brakes and for the direction. I have thought if with the Clio program and a scrapping card you could reprogram. I hope as possible solutions. Thank you.
14 years 5 days before #27538 by manual-mecanica
Manual-Mecanica Response on the Re: Start Scenic II 1.9 120 hp year 2004
Forget about the column bolt is also encoded,
you need a targeta or buy a 2manous avirgen and encode it.
Salu2
14 years 4 days before #27551 by manual-mecanica
The address column is solved by the car right now I have managed
14 years 4 days before #27559 by manual-mecanica
If it is a virgin, if not,
and you can only configure it with the Renault clip.
But one thing, do not be wrong that it does not block the column bolt does not mean that it starts, because it detects fault and does not start.
Salu2
14 years 4 days before #27577 by manual-mecanica
You have the Lucas to buy it, if you think of putting another card and do not encode it the computer is blocked and you get many more Lucas, Devil 12 has all the reason in what it says.
