BMXA transmission
14 years 1 month before #27334 by manual-mecanica
BMW transmission. Published by manual-mechanics
Good day, I have a 2002 Honda Civic with a BMXA transmission. We replaced the clutch discs on the second and fourth gear drums along with the double drum, as this is the only double drum the transmission has. After the repair, the transmission had the same problem and the new drum burned out again along with the clutch discs.
Any ideas?
14 years 1 month before #27371 by manual-mecanica
Manual-mechanics response on the topic Re: BMXA transmission
What was the problem?
14 years 1 month before #27376 by manual-mecanica
Good day, exactly 22 kilometers after the first repair, it started losing power until the gears wouldn't engage; it was slipping. When I opened it up again, the double drum was burned and the discs were fused together....help help help
