The digital temperature of a 307 does not go
14 years 1 week before #27239 by manual-mecanica
published by Manual-Mecanica does not go
I have a 307 and the temperature that digital brand that can be
14 years 1 week before #27240 by manual-mecanica
Manual-Mecanica response on the Re: I do not do the digital temperature of a 307
Check the operation of the bulb in the first place, if it does not bring Czech the state of the temperature sensor, threatens the ground cable to see if it marks nothing the problem can be on the board.
14 years 1 week before #27259 by manual-mecanica
Something feasible to make a scanner and with that they will check the temperature on the computer
if you have to check the dash dash
14 years 1 week before #27266 by manual-mecanica
Thank you very much for answering
14 years 5 days before #27541 by manual-mecanica
I think you mean the outside temperature.
If so, the sensor is usually in the right mirror.
If it is the Temp. Motor box
the picture is rare that you go, check the tempovija and wiring sensor that is sure to there is the
salu2
