Motor problems
13 years 8 months before #27225 by manual-mecanica
Motor problems published by Manual-Mecanica
Hello good night I tell you a week ago I send the engine of my car I have a Ford party and it has a sound like a shatter but you canbie the taquettes and nothing continues with the same noise sounds like taquettes sounds more when I turn it on that it is cold you have removed the noise but it sounds pus pus pus pus pus pus pus and has a fault that when I stop and the accelerate You can help me
13 years 8 months before #27235 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Problems
wave. I had a problem similar to a noise in the engine, I thought they were the taques but probe disconnecting the cam sensor and removed, then replaces it. Test if it serves you
13 years 7 months before #27242 by manual-mecanica
What type of oil did they make the car after repair, and the pus pus is like an air escape or as a blow of something?
13 years 7 months before #27262 by manual-mecanica
That@ño is the fiest@if it is 1.25 you have to gr@rle the t@that if it is 1.6 It is prov@ble that are@ndo l@sc@den@so a@fug@international from @ceite ... the 1.25 It is possible that you have
13 years 7 months before #27264 by manual-mecanica
Hello comrade, how do you have to send the car scanner to see if it does not have an accumulated code and solve anything you tell me what kind of code it is and I send you the answer greetings! 1
: Cheer:
